[GRASS5] [bug #2991] (grass) NVIZ fails to display 3D polygons
Maciek Sieczka werchowyna at pf.pl
Wed Mar 2 07:08:33 EST 2005
Subject: Re: [GRASS5] [bug #2991] (grass) NVIZ fails to display 3D polygons
> On Mon, Feb 14, 2005 at 08:43:43PM +0100, Request Tracker wrote:
>> this bug's URL: http://intevation.de/rt/webrt?serial_num=2991
>> Subject: NVIZ fails to display 3D polygons
>> Platform: GNU/Linux/i386
>> grass obtained from: Mirror of Trento site
>> grass binary for platform: Compiled from Sources
>> GRASS Version: grass-6.0.cvs_src_snapshot_2005_01_22
> There was a related fix in lib/ogsf/
> 2005-02-03 15:28  markus
>        * Gv3.c: fix for areas, now 2D polygons visible as boundaries again
>        (3D areas should be visible as filled polygons)
>> NVIZ doesn't display 3D polygon properly. Visualisation with 3D polygons
>> is impossible.
> Please try with a newer GRASS 6 version.
I did grass-6.0.cvs_src_snapshot_2005_02_12 and the problem remains.
And another one arose: it is only possible to change the color of the area
itself - the borderline is always black. Could it be possible to define the
color of the borderline and area separately?
> Hope this helps
Unfortuantelly it doesn't. But thanks for your care.
Cheers,
Maciek
