[GRASS5] [bug #2991] (grass) NVIZ fails to display 3D polygons
Maciek Sieczka
werchowyna at pf.pl
Wed Mar 2 17:09:43 EST 2005
Subject: Re: [GRASS5] [bug #2991] (grass) NVIZ fails to display 3D polygons
>>> this bug's URL: http://intevation.de/rt/webrt?serial_num=2991
>>> GRASS Version: grass-6.0.cvs_src_snapshot_2005_01_22
>> There was a related fix in lib/ogsf/
>> 2005-02-03 15:28 markus
ahh, now I see - you meant March and I thought you were reffering to
February
sorry for my absent-mindness but it would be better to follow one scheme of
dating fro the sake of clarity
Maciek
>> * Gv3.c: fix for areas, now 2D polygons visible as boundaries
>> again
>> (3D areas should be visible as filled polygons)
>>> NVIZ doesn't display 3D polygon properly. Visualisation with 3D polygons
>>> is impossible.
>> Please try with a newer GRASS 6 version.
> I did grass-6.0.cvs_src_snapshot_2005_02_12 and the problem remains.
> And another one arose: it is only possible to change the color of the area
> itself - the borderline is always black. Could it be possible to define
> the color of the borderline and area separately?
>> Hope this helps
> Unfortuantelly it doesn't. But thanks for your care.
> Cheers,
> Maciek
