[GRASS5] [bug #3054] (grass) r.info always displays the zone information (was: g.region -p always displays the zone information)
guest user via RT
grass-bugs at intevation.de
Wed Mar 2 07:20:54 EST 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3054
Request number 3054 was commented on by 'guest' (guest user).
Responding to this message will send mail to the requestor.
Request Tracker
rt at intevation.de
Cc: neteler at itc.it ; grass5 at grass.itc.it
SORRY! I meant r.info, not g.region!!! g.region is just fine!
Below is the appropriate report:
Please note that although the location and the raster are in Stereographic
projection there is "zone (0)" comment in the r.info's report.
The location is not UTM first of all so any "zone" info does not fit. Secondly
the UTM zone 0 is somewhere on the west coast of North America while the
location here is Poland, Europe, so this might be eventually missleading.
GRASS 6.0.cvs:~ > r.info u65_p190r024_7p20010524_z33_nn80
| Layer: u65_p190r024_7p20010524_z33_n Date: Fri Feb 25 21:01:05 2005 |
| Mapset: PERMANENT Login of Creator: pingwin |
| DataBase: /home/grassdata |
| Title: ( u65_p190r024_7p20010524_z33_nn80 ) |
| Type of Map: raster Number of Categories: 255 |
| Data Type: CELL |
| Rows: 16265 |
| Columns: 18056 |
| Total Cells: 293680840 |
| Projection: Stereographic (zone 0) |
| N: 5746474.98553376 S: 5514698.73553376 Res: 14.25 |
| E: 3883196.56575737 W: 3625898.56575737 Res: 14.25 |
| Range of data: min = 0 max = 255 |
| Data Source: |
| Data Description: |
| generated by r.in.gdal |
-------------------------------------------- Managed by Request Tracker
