[GRASS5] [bug #3078] (grass) ecw format
Maciek Sieczka werchowyna at pf.pl
Thu Mar 10 03:49:46 EST 2005
Lourdes
It depends whether you GDAL instalation was built with ECW support. If it
was you should be able to load ECW images directly into Grass with
r.in.gdal.
I guess that the latest FWtools release provides GDAL with an improved ECW
driver. And if you really just want to *see* your ECW image use OpenEV
shipped together with FWtools.
Maciek
P.S.
Why did you report your issue a bug?
----- Original Message -----
From: "Request Tracker" <grass-bugs at intevation.de>
To: <grass5 at grass.itc.it>
Sent: Thursday, March 10, 2005 8:46 AM
Subject: [GRASS5] [bug #3078] (grass) ecw format
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3078
> Subject: ecw format
> it is possible to see images in ecw format directly in grass, without
> converting it to tiff?
> thanks,
> Lourdes
> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> http://grass.itc.it/mailman/listinfo/grass5
