[GRASS5] [bug #3089] (grass) v.overlay: support for atype=point
Request Tracker grass-bugs at intevation.de
Sun Mar 13 22:41:51 EST 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3089
Subject: v.overlay: support for atype=point
It would be nice if you could use v.overlay with atype=point, e.g. to select
points not included by an area.
Work around: v.in.region + 'v.overlay op=not' to make an inverse of your area
then use v.select.
A 'v.select op=not' would be nice to do the same thing.
Hamish
-------------------------------------------- Managed by Request Tracker
