[GRASS5] Angle of incidence in viewshed/line of sight
Roger Bivand
Roger.Bivand at nhh.no
Tue Mar 15 15:35:16 EST 2005
On Sun, 13 Mar 2005, Glynn Clements wrote:
> Paul Kelly wrote:
> > >> Did we not already decide that now that GRASS has shared libraries, it
> > >> only needs the header files to be included in the binary distribution?
> > >> Then only the new module needs to be compiled (and a script can be
> > >> written to do this automatically).
> > >> Radim may even have already done this (added the headers to the install).
> > > Am I completely wrong that for a module linking against say -lgis, you
> > > still need a copy of libgis.a somewhere on the -L?
> > Not if there is a shared library there--it can link against it instead.
> I think that the point is that binary distributions should always
> include the libraries regardless of whether they are shared or static.
> IIRC, we currently only include the libraries if they are shared
> libraries.
Yes, as of now 5.4.0 and 6.0.0 only install the *.so.
> From a packaging (RPM etc) perspective, static libraries would
> normally go into a separate -devel package, along with the headers,
> while shared libraries would go into the main package.
That is an excellent idea - it would help the add-on modules a great deal.
Today a user is reporting failure to compile gstat against 5.4.0, with the
gstat configure:
if test -d $with_grass ; then
AC_DEFINE(HAVE_LIBGIS)
LIBS="$LIBS -L $with_grass/lib"
INCLUDES="$INCLUDES -I$with_grass/include"
AC_CHECK_LIB(grass_gis, G_gisinit, GISLIB="-lgrass_gis -lgrass_datetime",
AC_CHECK_LIB(gis, G_gisinit, GISLIB="-lgis -ldatetime"))
LIBS="$LIBS $GISLIB -lz"
fi
failing when $with_grass is set properly (I believe, and have tried it
myself) but /lib only has the *.so. This seems to be an example of the
problems of not having *.a installed when needed for development.
Roger
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand at nhh.no
