[GRASS5] v.in.ascii updates
Miguel A. Altamirano del C
mgaac at yahoo.com
Wed Mar 16 11:29:19 EST 2005
--- Hamish <hamish_nospam at yahoo.com> wrote:
> Hi,
> I'm looking to do some v.in.ascii updates, I thought
> I'd trawl for
> comments first.. most deal with format=point mode.
> Fairly straight forward updates:
> + update to use G_getl2() to make MacOS9 ascii
> import work.
> + add skip= option to skip any header lines when
> format=point
> (e.g. column headings in cvs file)
> + add a -s flag to write those skipped header lines
> to the map's
> meta-data hist file (v.info -h).
> Debatable updates:
> ? skip any line starting with a '#' in input file.
> (could silently ignore data..??)
> ? skip blank lines in input file.
> (currently extra newlines at EOF break import of
> points)
> ? strip "quotes" from both ends of varchar input.
> ? rename format=standard to format=grass as
> format=point is default,
> so standard mode is non-standard. Confusing! I'll
> fix any scripts/.
> You can expect me to go ahead and do all these
> things if noone objects.
> Hamish
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Also if can puts an indicative for the format to
import the values "columns='variable double f8.2' "
for when it be used with other instruction put excatly
the format that was reading; p.e. "d.vect -c file
display=attr attrcol=variable"
LCA Miguel A. Altamirano del C.
"Los Mexicanos llevamos la fiesta en la garganta"
Tel. 01(232)32 45208
La belleza de la meteorología radica en saber
pronosticarla y no simplemente en estudiarla
(Miguel A. Altamirano 28-5-00)
_________________________________________________________
Do You Yahoo!?
Información de Estados Unidos y América Latina, en Yahoo! Noticias.
Visítanos en http://noticias.espanol.yahoo.com
