[GRASS5] How to merge attribute files after v.patch?
Michael Barton
michael.barton at asu.edu
Thu Mar 17 10:34:00 EST 2005
I made a little script to solve this problem. It's still a bit rough but
seems to work pretty well. When I get a bit of time, I'll clean it up and
put it on the GRASS WIKI.
I've attached it here.
Michael
____________________
C. Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
> From: Allan Metts <ametts2 at mindspring.com>
> Date: Wed, 16 Mar 2005 07:51:42 -0500
> To: <grass5 at grass.itc.it>
> Subject: [GRASS5] How to merge attribute files after v.patch?
> Hi all,
> I have geometry stored in shape files (linked in with v.external), and
> attribute files stored in dbf files.
> I can combine two shape files into one with v.patch -- but v.patch doesn't do
> anything with the dbf attributes. So I'm looking for a good way to combine
> the attribute files after performing v.patch.
> I tried INSERT INTO usxxxxst (SELECT * from akxxxxst), but it doesn't look
> like support for this type of operation exists in GRASS SQL yet.
> Can anyone suggest an easy utility (GRASS or otherwise) that can append the
> contents of one dbf file into another?
> Thanks in advance,
> Allan
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050317/672e3df6/v.obj
