[GRASS5] tcl/tk chinese fonts issue
Glynn Clements
glynn at gclements.plus.com
Fri Mar 18 16:03:55 EST 2005
Markus Neteler wrote:
> > > > Today I have tested the po file, it worked fine. But the font in the
> > > > GUI looks ugly , I want to change the font, but I don't know how to
> > > > do. Can you give me some suggestion?
> > About the font, I think one picture is more clear than thousands words :)
> [example attached]
> Actually I don't know how to change the font for the tcl/tk
> windows.
You can change it through X resources.
However Tcl's handling of X resources is rather broken; in particular,
program-specific settings don't work if the program name contains any
dots (as is the case for d.m.tcl).
You can override the name using the -name switch e.g.:
exec "$GRASS_WISH" "$GISBASE/etc/dm/d.m.tcl" -name d_m_tcl
[I suggest making the above change to the d.m script, in both places.]
You can then set a font resource in ~/.Xdefaults with e.g.:
d_m_tcl*font: -adobe-helvetica-bold-r-*-*-16-*-*-*-*-*-iso8859-1
Also, it chooses the last matching key (not the most specific match),
so you have to place the above setting after any generic font
setting.
