[GRASS5] tcl/tk chinese fonts issue
nilarcs
nilarcs at gmail.com
Mon Mar 21 04:28:31 EST 2005
Yeah , it's great!
Thank you very much!
I think you should add this to the FAQ , someone else maybe need this too :)
(BTW:Don't forget "xrdb -merge .Xdefaults" after you change the
.Xdefaults file.)
Zhang Jun
2005-3-21
On Fri, 18 Mar 2005 21:03:55 +0000, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
> > > > > Today I have tested the po file, it worked fine. But the font in the
> > > > > GUI looks ugly , I want to change the font, but I don't know how to
> > > > > do. Can you give me some suggestion?
> > > About the font, I think one picture is more clear than thousands words :)
> > [example attached]
> > Actually I don't know how to change the font for the tcl/tk
> > windows.
> You can change it through X resources.
> However Tcl's handling of X resources is rather broken; in particular,
> program-specific settings don't work if the program name contains any
> dots (as is the case for d.m.tcl).
> You can override the name using the -name switch e.g.:
> exec "$GRASS_WISH" "$GISBASE/etc/dm/d.m.tcl" -name d_m_tcl
> [I suggest making the above change to the d.m script, in both places.]
> You can then set a font resource in ~/.Xdefaults with e.g.:
> d_m_tcl*font: -adobe-helvetica-bold-r-*-*-16-*-*-*-*-*-iso8859-1
> Also, it chooses the last matching key (not the most specific match),
> so you have to place the above setting after any generic font
> setting.
> Glynn Clements <glynn at gclements.plus.com>
