[GRASS5] i.points & G_parser()
Fri Mar 18 20:35:43 EST 2005
I just modified i.points to use G_parser(). Result: i.points works
better from the command line but GUI from command line and d.m fail as
it tries to run all the interactive text input stuff in the tcltk
window.
Is there a solution for this or will i.points have to continue to be
non-conformal? Is the only way to move interactive data entry onto
graphics display window?
thanks for any ideas,
Hamish
