[GRASS5] i.points & G_parser()
Glynn Clements
glynn at gclements.plus.com
Sat Mar 19 10:36:09 EST 2005
Hamish wrote:
> I just modified i.points to use G_parser(). Result: i.points works
> better from the command line but GUI from command line and d.m fail as
> it tries to run all the interactive text input stuff in the tcltk
> window.
> Is there a solution for this or will i.points have to continue to be
> non-conformal?
One solution would be to add a new function to parser.c which an
application can use to indicate that it requires a terminal, e.g.
G_i_need_a_terminal().
The generate_tcl() function would propagate this information so that
run_cmd would know that it needs to run the command in a terminal.
> Is the only way to move interactive data entry onto
> graphics display window?
A Tcl/Tk version of the Vask library would be a useful addition.
