[GRASS5] v.in.ascii updates
Hamish
hamish_nospam at yahoo.com
Mon Mar 21 04:06:01 EST 2005
> > I finally got around to installing valgrind to check where the
> > memory leaks are.
> Can you do the same for the driver?
Sure; but can you provide a command line test(s)?
Valgrind seems to go through all calls (even glibc, shared libs, etc) as
they are made during runtime, so to test a part of the driver you just
need to make a call to it. sorry, I don't know much about databases or
how the drivers work to come up with an intelligent test myself.
Hamish
