[GRASS5] v.in.ascii updates
Radim Blazek
blazek at itc.it
Mon Mar 21 04:47:46 EST 2005
Hamish wrote:
>>>I finally got around to installing valgrind to check where the
>>>memory leaks are.
>>Can you do the same for the driver?
> Sure; but can you provide a command line test(s)?
What do you mean?
> Valgrind seems to go through all calls (even glibc, shared libs, etc) as
> they are made during runtime, so to test a part of the driver you just
> need to make a call to it. sorry, I don't know much about databases or
> how the drivers work to come up with an intelligent test myself.
The module creates the driver as a new process (fork-exec). I think that
you have to use --trace-children=yes.
Radim
