[GRASS5] v.in.ascii updates
Hamish
hamish_nospam at yahoo.com
Mon Mar 21 21:30:41 EST 2005
> >>>I finally got around to installing valgrind to check where the
> >>>memory leaks are.
> >>Can you do the same for the driver?
> The module creates the driver as a new process (fork-exec). I think
> that you have to use --trace-children=yes.
ok,
CMD="v.in.ascii in=test_pts.dat out=test4 --o"
valgrind -v --tool=addrcheck --leak-check=yes --trace-children=yes $CMD
Memcheck log:
http://bambi.otago.ac.nz/hamish/grass/memleak/v.in.ascii/memchk_child.txt
Look for process 2030 (dbf):
==2230== 36748400 bytes in 48100 blocks are definitely lost in loss record 15 of 16
==2230== at 0x3414CFE5: calloc (vg_replace_malloc.c:176)
==2230== by 0x3416AAB9: sqpInitStmt (alloc.c:30)
==2230== by 0x804B09F: execute (dbfexe.c:58)
==2230== by 0x804D5CA: db__driver_execute_immediate (execute.c:29)
Also graphical Massif test, heap growth analysis: (end of page)
Hamish
