[GRASS5] v.in.ascii updates
Radim Blazek blazek at itc.it
Tue Mar 22 03:59:47 EST 2005
It's funny, sqpFreeStmt(st) was realy missing in execute(), I thought
that I had checked it already before. 50000 points - dbf: 100MB -> 10MB
Thank you Hamish. Should I fix that also in the 6.0 branch?
Finally Helena can use 6.
Radim
Hamish wrote:
>>>>>I finally got around to installing valgrind to check where the
>>>>>memory leaks are.
>>>>Can you do the same for the driver?
>>The module creates the driver as a new process (fork-exec). I think
>>that  you have to use --trace-children=yes.
> ok,
> CMD="v.in.ascii in=test_pts.dat out=test4 --o"
> valgrind -v --tool=addrcheck --leak-check=yes --trace-children=yes $CMD
> Memcheck log:
>  http://bambi.otago.ac.nz/hamish/grass/memleak/v.in.ascii/memchk_child.txt
> Look for process 2030 (dbf):
> ==2230== 36748400 bytes in 48100 blocks are definitely lost in loss record 15 of 16
> ==2230==    at 0x3414CFE5: calloc (vg_replace_malloc.c:176)
> ==2230==    by 0x3416AAB9: sqpInitStmt (alloc.c:30)
> ==2230==    by 0x804B09F: execute (dbfexe.c:58)
> ==2230==    by 0x804D5CA: db__driver_execute_immediate (execute.c:29)
> Also graphical Massif test, heap growth analysis: (end of page)
> Hamish
