[GRASS5] NVIZ: Marooned
peter.loewe at gmx.de peter.loewe at gmx.de
Tue Mar 22 05:51:34 EST 2005
apparently the current improvements in NVIZ did cause side
effects:
The animation panel (the simple one) features now a mis-alignment
bug of the center coordinate.
Here's how to experience it: Create a circular flight-path,
looking down at the centre of the current region.
Let's assume we start in the south (S): Set the _first_ and the
last key frame to the current position. Now move the puck to the
most northern point and set another keyframe at the half-way mark
of the keyframe-bar. No magic so far.
NOW try to set likewise the most eastern and most western
positions of the flightpath (at 1/4 and 3/4 of the keyframe-bar).
If the magic works, you should get a blank display, the position
being somewhere way off in the boondocks. Moving the puck shows
that the center coordinate was altered.
Up till Version 6.0 NVIZ didn't behave like that.
Suggested workaround: Use the "center" button for realignment.
Peter
Dr. Peter Löwe
Diplom-Geograph
<loewe at geomancers.net>
<peter.loewe at gmx.de>
DSL Komplett von GMX +++ Supergünstig und stressfrei einsteigen!
AKTION "Kein Einrichtungspreis" nutzen: http://www.gmx.net/de/go/dsl
