[GRASS5] NVIZ: Marooned
Massimo Cuomo
m.cuomo at acsys.it
Tue Mar 22 08:36:59 EST 2005
Hello Bob and the others.
First of all thank you for using (and testing) the new flythrough.
What I mostly changed in order to get the kanimator working, was to
change get/set_focus o get/set_viewdir. But I did it only for kanimator
and not for the simple animator, so maybe changing these into the simple
animator could solve the problem. Furthermore as in this way the view is
not anymore toward the center, this can affect the results of the
position panel (that I never use).
Anyone that already knows where to put his/her hands, is welcome.
Otherwise I'll try to see what I can do as soon as I can.
Massimo
Bob Covill wrote:
> Hi Massimo,
> I have found a couple of side effects related to the recent updates.
> They are probably related to the message below.
> The first (fairly minor) is that height slider is not updated when
> switching back and forth between the "eye" view and "fly" view. This
> should be a fairly straight forward to fix. We probably just need to add
> something in the change_display procedure in panel_main.tcl to update
> the new height.
> I have also noted that if in fly-mode the position panel does not pick
> up the correct "real" to-from positions. If you open the "eye" and
> "center" view menus the correct(?) "real" to-from position is set.
> Lastly, I created a small fly-through with the "fly" menu (which worked
> really well) and saved it from the keyframe panel. The fly-through
> re-played fine in the current session, but when I re-start NVIZ and load
> the saved animation, the keyframe positions are off.
> I suspect that most of these problems are related. I will try and
> investigate a little further.
> Bob
> peter.loewe at gmx.de wrote:
>> Hi,
>> apparently the current improvements in NVIZ did cause side effects:
>> The animation panel (the simple one) features now a mis-alignment bug
>> of the center coordinate. Here's how to experience it: Create a
>> circular flight-path, looking down at the centre of the current
>> region. Let's assume we start in the south (S): Set the _first_ and
>> the last key frame to the current position. Now move the puck to the
>> most northern point and set another keyframe at the half-way mark of
>> the keyframe-bar. No magic so far. NOW try to set likewise the most
>> eastern and most western positions of the flightpath (at 1/4 and 3/4
>> of the keyframe-bar).
>> If the magic works, you should get a blank display, the position being
>> somewhere way off in the boondocks. Moving the puck shows that the
>> center coordinate was altered. Up till Version 6.0 NVIZ didn't behave
>> like that.
>> Suggested workaround: Use the "center" button for realignment.
>> Peter
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
