[GRASS5] v.in.ascii updates
Radim Blazek blazek at itc.it
Wed Mar 23 04:06:20 EST 2005
Hamish wrote:
>>It's funny, sqpFreeStmt(st) was realy missing in execute(), I thought
>>that I had checked it already before. 50000 points - dbf: 100MB ->
>>10MB
> cool.
> I can now import the 1.1 million point sample LIDAR data set
> (lidaratm2.txt.gz, 31.5mb uncompressed) from-
>   http://mpa.itc.it/grasstutor/data_menu2nd.phtml
> According to top, v.in.ascii using that file drives the dbf process up
> to 248mb now and during "Registering lines" part the v.in.ascii process
> goes up to 435mb memory use -- still a few small leaks? re-run valgrind?
> (I don't understand why a point-only vector file is worrying about
> lines?)
>>Thank you Hamish. Should I fix that also in the 6.0 branch?
> seems like a perfect candidate for 6.0.1 to me.
It must be tested a bit in 6.1 first, I think.
Radim
