[GRASS5] Re: [GRASS5] [bug #3116] (grass) invalid homepage
jon at jzylstra.com jon at jzylstra.com
Fri Mar 25 09:32:01 EST 2005
guest user via RT <grass-bugs at intevation.de> wrote on 03/25/2005,
10:36:09 AM:
> > invalid homepage perhaps just tip of iceberg
> it's not that dramatic... and a known issue.
> You also reported it already:
>  http://intevation.de/rt/webrt?serial_num=2838&display=History
> HTML fixes are welcome.
> Markus
Re: Bug #2838 & #3116
Attached is new, validating html code to replace the html code submitted
on the bottom of bug report #2838. The minor correction required is
that <form> and <center> cannot be inside of <font>
I haven't had the time to dig into any coding ... but I may have some
time to work on html validation. I'll look into it when I have the
chance.
Jonathan A. Zylstra
Type: application/defanged
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050325/3da3f18e/new.bin
