[GRASS5] Re: [GRASS5] [bug #3116] (grass) invalid homepage
Markus Neteler neteler at itc.it
Sun Mar 27 11:22:21 EST 2005
On Fri, Mar 25, 2005 at 03:32:01PM +0100, jon at jzylstra.com wrote:
> guest user via RT <grass-bugs at intevation.de> wrote on 03/25/2005,
> 10:36:09 AM:
> > > invalid homepage perhaps just tip of iceberg
> > it's not that dramatic... and a known issue.
> > You also reported it already:
> >  http://intevation.de/rt/webrt?serial_num=2838&display=History
> > HTML fixes are welcome.
> > Markus
> Re: Bug #2838 & #3116
> Attached is new, validating html code to replace the html code submitted
> on the bottom of bug report #2838. The minor correction required is
> that <form> and <center> cannot be inside of <font>
> I haven't had the time to dig into any coding ... but I may have some
> time to work on html validation. I'll look into it when I have the
> chance.
> Jonathan A. Zylstra
For the record: fix applied.
Markus
