[GRASS5] [bug #3118] (grass) Edit box cannot edit
Request Tracker
grass-bugs at intevation.de
Sat Mar 26 04:12:38 EST 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3118
Subject: Edit box cannot edit
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
On Fedora Core3(i386) and SUSE 9.2 (i386), I compiled the source of GRASS 5.4 (also GDAL, PROJ4). Each command of GRASS 5.4 could well perform on the shell. However, in the dialog window of GUI, I cannot edit the string within the edit boxes, althouth the bottons within the dialog window could well perform and select the potions. In the edit box, I pressed the key, but non of changes could appeared.
-------------------------------------------- Managed by Request Tracker
