[GRASS5] [bug #3118] (grass) Edit box cannot edit
Sat Mar 26 23:07:43 EST 2005
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3118
> Subject: Edit box cannot edit
> Platform: GNU/Linux/i386
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> On Fedora Core3(i386) and SUSE 9.2 (i386), I compiled the source of
> GRASS 5.4 (also GDAL, PROJ4). Each command of GRASS 5.4 could well
> perform on the shell. However, in the dialog window of GUI, I cannot
> edit the string within the edit boxes, althouth the bottons within the
> dialog window could well perform and select the potions. In the edit
> box, I pressed the key, but non of changes could appeared.
are you trying to edit the text in the box on the bottom of the GUI
(that won't work) or in the text box of each option?
Hamish
