[GRASS5] v.in.garmin
Hamish
hamish_nospam at yahoo.com
Wed Mar 30 01:10:18 EST 2005
> due to changes in v.in.ascii the script v.in.garmin is currently
> broken. Changing the string "catcol" to "cat" in v.in.garmin fixes the
> biggest problems and the script can at least be used to import
> Waypoints/Tracks and Routes as POINTs.
fixed in cvs.
> There's still another bug lurking: track/route-vectors are being
> created, but the geometry is garbled, which makes 'em unusable.
works for me.
G61> v.in.garmin -v -t out=t_trk
G61> v.build t_trk
Building topology ...
12 primitives registered
Building areas: 100%
0 areas built
0 isles built
Attaching islands:
Attaching centroids: 100%
Topology was built.
Number of nodes : 24
Number of primitives: 12
Number of points : 0
Number of lines : 12
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
[no errors there..]
G61> d.vect t_trk
[looks fine]
Could you explain more about "geometry is garbled" ?
Are there any error messages in the v.in.garmin output?
Are you using DBF database?
Hamish
