[GRASS5] Import NOAA AVHRR .dat files
Ricardo Armas rgoncalves at criticalsoftware.com
Wed May 4 12:08:50 EDT 2005
Hello.
Im trying to import a .dat file with r.in.bin.
r.in.bin input=/home/neb_15.dat output=neb_exp bytes=1 north=44.80
south=35.01 east=-1.14 west=-12.20 rows=89 cols=79 -b
However, I always get an error message like this:
Bytes do not match File size
File size 171262... Total Bytes 7031
Try bytes=24 or adjusting input parameters
The file header looks like this
#LLMATRIX,
NORTH      = 44.80,
WEST       = 347.80,
GRID       = 0.14/0.11,
NLAT       = 89,
NLON       = 79
#DATA
Does anyone have a solution?
Thanks in advance,
Ricardo
DISCLAIMER: This message may contain confidential information or privileged material and is intended only for the individual(s) named. If you are not a named addressee and mistakenly received this message you should not copy or otherwise disseminate it: please delete this e-mail from your system and notify the sender immediately. E-mail transmissions are not guaranteed to be secure or error-free as information could be intercepted, corrupted, lost, destroyed, arrive late or incomplete or contain viruses. Therefore, the sender does not accept liability for any errors or omissions in the contents of this message that arise as a result of e-mail transmissions. Please request a hard copy version if verification is required. Critical Software.
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20050504/ad8a0895/attachment.html
