[GRASS5] [bug #3201] (grass) v.in.ogr: failed import of shape file
Request Tracker
grass-bugs at intevation.de
Wed May 4 20:11:26 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3201
Subject: v.in.ogr: failed import of shape file
when trying to load a shapefile..
G6> v.in.ogr dsn=. layer=Depth_GD2K out=Depth
A datum name nzgd2k (New_Zealand_Geodetic_Datum_2000) was specified without
transformation parameters.
Note that the GRASS default for nzgd2k is towgs84=0.000,0.000,0.000.
Projection of input dataset and current location appear to match.
Proceeding with import...
Layer: Depth_GD2K
Building topology ...
Registering lines: v.in.ogr: split_q.c:65: RTreeClassify: Assertion
`!p->taken[i]' failed.
Aborted
QGIS loads it fine.
Happens both with GRASS 6.0 Debian package and self-compiled GRASS 6.1-cvs on
different machines.
File is from ArcGIS 9(?).
ideas?
Hamish
-------------------------------------------- Managed by Request Tracker
