[GRASS5] [bug #3201] (grass) v.in.ogr: failed import of shape
file
Radim Blazek
blazek at itc.it
Thu May 5 04:11:55 EDT 2005
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3201
> Subject: v.in.ogr: failed import of shape file
> when trying to load a shapefile..
> G6> v.in.ogr dsn=. layer=Depth_GD2K out=Depth
> A datum name nzgd2k (New_Zealand_Geodetic_Datum_2000) was specified without
> transformation parameters.
> Note that the GRASS default for nzgd2k is towgs84=0.000,0.000,0.000.
> Projection of input dataset and current location appear to match.
> Proceeding with import...
> Layer: Depth_GD2K
> Building topology ...
> Registering lines: v.in.ogr: split_q.c:65: RTreeClassify: Assertion
> `!p->taken[i]' failed.
> Aborted
> QGIS loads it fine.
> Happens both with GRASS 6.0 Debian package and self-compiled GRASS 6.1-cvs on
> different machines.
> File is from ArcGIS 9(?).
> ideas?
> Hamish
You have to debug lib/vector/rtree/.
Radim
