[GRASS5] Ps.map wish/question
Tue May 17 04:46:26 EDT 2005
Hamish wrote:
> the ultimate way would be to have a command line flag --psmap or
> something to have the display modules output their commands in ps.map
> form. These could be cat-ed together for a prototype ps.map command
> script. Perhaps that is a lot more trouble than it is worth, and a
> shell/perl/python script to translate a couple of the more common d.*
> commands from d.save into a ps.map command file is all that is needed.
Only a few d.* commands have ps.map equivalents. For most of those,
ps.map only has an approximate equivalent. Also, you can't combine
ps.map commands in the same way that you can combine d.* commands.
The most obvious example is that there is no ps.map equivalent of:
	d.rast map1
	d.rast -o map2
as ps.map only allows a single raster, and doesn't have an equivalent
of the -o switch (and that could only be implemented for level 3
PostScript; earlier versions don't support masked images).
More generally, the d.* commands draw directly to the monitor, whereas
ps.map commands tend to be stored up, and the rendering only starts
once all of the commands have been read. The order in which commands
are "executed" (i.e. rendered) doesn't necessarily correspond to their
order in the input file.
