[GRASS5] Re: [bug #3246] (grass) d.vect.thematic fails when the map is in another mapset
Daniel Calvelo Aros dcalvelo at minag.gob.pe
Fri May 20 13:22:08 EDT 2005
Sent: Fri, 20 May 2005 10:12:41 -0700
> I tend to agree with you that
> min - max
> looks better than
> >min - max
> although the second one is more accurate.
> What does everyone else think?
I'd like the math standard :
[min ; cut1]
]cut1 ; cut2]
]cutn ; max]
Note the *included* min. I'll see if I can put that into your current script,
Michael.
Daniel.
