[GRASS5] Re: [GRASSLIST:6835] GRASS on HP ProLiant ML570 (solved)
Mon May 23 00:33:56 EDT 2005
> > SuSE 9.0 and > 9.0 supports intel 64bit and has QT > 3.1.
> Does anyone know how other distros perform for 64bit?
No idea on comparative performance, but the AMD64 port of Debian has:
(incl. Intel with EM64T extension)
  http://www.debian.org/ports/amd64/
A complete 64bit userland
The AMD64 port is thoroughly 64bit, allowing the user to benefit from
all advantages this architecture has compared to i386:
    * no memory segmentation in low and high memory
    * up to 32TB virtual address space per process (instead of 2GB)
    * 128GB physical memory support instead of 4GB (or 64GB with the PAE
	extension)
    * 16 registers in the CPU instead of 8
    * gcc defaults to sse math instead of 387 fpu
    * gcc omits frame-pointers by default
    * compilation time optimization uses a common base for amd64/em64t
	instead of legacy i386 cruft
    * memory pages are not executable by default
Native execution of legacy 32bit binaries is supported by the kernel,
and core libraries are provided by the ia32-libs package.
see also
 http://lists.debian.org/debian-devel-announce/2005/05/msg00004.html
(I've not used it myself)
Hamish
