[GRASS5] GUI hardcoded otions order
Maciek Sieczka
werchowyna at epf.pl
Mon May 23 04:37:45 EDT 2005
Radim, Michael
About http://intevation.de/rt/webrt?serial_num=3017.
Maciek Sieczka wrote:
> I encounter a segfault with one particular dataset with the following
> options:
> GRASS 6.0.cvs:~ > v.clean input=i output=j type=area err=j_err
> tool=break,rmdupl,rmdac,bpol,rmarea
Radim Blazek wrote:
>>I fixed that
Thanks!
>>, however:
>>1) bpol should be used as first cleaning tool, it does the same as
>>break, but it is faster on clean (identical boundaries) polygons
I can't change the order of cleaning tools using v.clean in GUI. The order
is hardcoded. Could that be fixed Michael? Options order issue also refers
to v.type in GUI http://intevation.de/rt/webrt?serial_num=2969.
>>2) bpol works only with type=boundary, the same break,rmdupl etc.
Radim, do you mean that "rmdupl" and "break" should not be used with
type=line?
Maciek
