[GRASS5] Re: GUI hardcoded otions order
Michael Barton
michael.barton at asu.edu
Mon May 23 18:56:20 EDT 2005
Maciek,
I don't have any expertise as a c-programmer. I only work on the TclTk
scripts that create the GIS Manager and on shell scripts that I've written
(e.g. D.vect.thematic) or updated. Sorry, but you'll have to ask someone
else this.
Michael
On 5/23/05 1:37 AM, "Maciek Sieczka" <werchowyna at epf.pl> wrote:
> Radim, Michael
> About http://intevation.de/rt/webrt?serial_num=3017.
> Maciek Sieczka wrote:
>> I encounter a segfault with one particular dataset with the following
>> options:
>> GRASS 6.0.cvs:~ > v.clean input=i output=j type=area err=j_err
>> tool=break,rmdupl,rmdac,bpol,rmarea
> Radim Blazek wrote:
>>> I fixed that
> Thanks!
>>> , however:
>>> 1) bpol should be used as first cleaning tool, it does the same as
>>> break, but it is faster on clean (identical boundaries) polygons
> I can't change the order of cleaning tools using v.clean in GUI. The order
> is hardcoded. Could that be fixed Michael? Options order issue also refers
> to v.type in GUI http://intevation.de/rt/webrt?serial_num=2969.
>>> 2) bpol works only with type=boundary, the same break,rmdupl etc.
> Radim, do you mean that "rmdupl" and "break" should not be used with
> type=line?
> Maciek
____________________
C. Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
