[GRASS5] d.vect.thematic on Mac OS X
Thomas Adams Thomas.Adams at noaa.gov
Mon May 23 07:55:20 EDT 2005
Michael & Daniel,
Thanks for your help!
Regards,
Tom
Michael Barton wrote:
>Thanks Daniel.
>Here is a more "Mac" way to install it.
>This assumes that you are using Lorenzo Moretti's Mac binaries.
>1. Go to your grass folder (in Applications).
>2. Select the GRASS program file. I did this for grass61cvs, but it should
>work for grass60 also.
>3. Hold down the control key and click with the mouse (or right click on a
>3-button mouse).
>4. Select "Show package contents"
>5. Navigate to Contents/Resources/grass-6.1cvs/scripts (or
>.../grass-6.0/scripts)
>6. Put d.vect.thematic and v.univar.sh in the scripts folder
>7. Voila, you can run them from the GRASS command line (I'll add them to the
>GIS Manager menu soon).
>Note that sometimes the execute permission gets turned off when these files
>travel across the ether. You can not turn this on via the Mac "get info"
>dialog for some weird reason. You can either use the chmod command from the
>terminal to do this or download a nifty utility called BatChmod from
>www.versiontracker.com that will allow you to set the execute permissions.
>Michael
>______________________________
>Michael Barton, Professor of Anthropology
>School of Human Evolution and Social Change
>Arizona State University
>Tempe, AZ  85287-2402
>USA
>voice: 480-965-6262; fax: 480-965-7671
>www: http://www.public.asu.edu/~cmbarton
>>From: Daniel Calvelo Aros <dcalvelo at minag.gob.pe>
>>Reply-To: <daniel.calvelo at minag.gob.pe>
>>Date: Fri, 20 May 2005 14:22:50 -0500
>>To: Thomas Adams <Thomas.Adams at noaa.gov>, Michael Barton
>><michael.barton at asu.edu>
>>Cc: <grass5 at grass.itc.it>
>>Subject: Re: [GRASS5] d.vect.thematic on Mac OS X
>>I'm on MacOSX right now. Quick and dirty, since "." is in the PATH:
>>1. Unpack Michael's thematic.tgz;
>>2. start grass (I use 6);
>>3. within grass cd to the thematic/d.vect.thematic directory;
>>4. issue a 'cp ../v.univar.sh/v.univar.sh .'
>>5. presto.
>>You won't see colors in the graphical legend, though (you need CVS for that).
>>Daniel
>>-- Daniel Calvelo Aros
>>---------- Original Message -----------
>>From: "Thomas Adams" <Thomas.Adams at noaa.gov>
>>To: Michael Barton <michael.barton at asu.edu>
>>Cc: grass5 at grass.itc.it
>>Sent: Fri, 20 May 2005 14:07:20 -0400
>>Subject: [GRASS5] d.vect.thematic on Mac OS X
>>>Michael,
>>>I would like to play with d.vect.thematic. I have installed
>>>LorenzoMoretti's GRASS distribution for Mac OS X for both 5.4 & 6.0
>>>anduse both. What do I need to do to try it out? Thanks for your help.
>>>Regards,
>>>Tom
>>>If you want to change your local version, please go right ahead and
>>>see how it looks.
>>>Let's not change the cvs version until we have a consensus (if
>>>possible). For work in my field (archaeology) and from what I know
>>>of geography, the notation
>>>]min ; max]
>>>would be meaningless--although it might be perfect for your field
>>>Michael
>>>USA
>>>Date: Fri, 20 May 2005 12:22:08 -0500
>>>To: Michael Barton <michael.barton at asu.edu>, Maciek Sieczka
>>><werchowyna at epf.pl>, Paolo Cavallini via RT <grass-
>>>bugs at intevation.de> Cc: grass devel <grass5 at grass.itc.it> Subject:
>>>Re: [GRASS5] Re: [bug #3246] (grass) d.vect.thematic fails when the
>>>map is in another mapset
>>>From: Michael Barton <michael.barton at asu.edu>
>>>Sent: Fri, 20 May 2005 10:12:41 -0700
>>>I tend to agree with you that
>>>min - max
>>>looks better than
>>>min - max
>>>although the second one is more accurate.
>>>What does everyone else think?
>>>I'd like the math standard :
>>>[min ; cut1]
>>>]cut1 ; cut2]
>>>]cutn ; max]
>>>Note the *included* min. I'll see if I can put that into your
>>>current script, Michael.
>>>Daniel.
>>>_______________________________________________
>>>grass5 mailing list
>>>http://grass.itc.it/mailman/listinfo/grass5
>>>Thomas E Adams
>>>National Weather Service
>>>Ohio River Forecast Center
>>>1901 South State Route 134
>>>Wilmington, OH 45177
>>>EMAIL: thomas.adams at noaa.gov
>>>VOICE: 937-383-0528
>>>FAX: 937-383-0033
>>------- End of Original Message -------
Thomas E Adams
VOICE:	937-383-0528
FAX:	937-383-0033
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20050523/226f3aec/attachment.html
