[GRASS5] d.vect.thematic on Mac OS X
Michael Barton
michael.barton at asu.edu
Fri May 20 18:31:28 EDT 2005
Thanks Daniel.
Here is a more "Mac" way to install it.
This assumes that you are using Lorenzo Moretti's Mac binaries.
1. Go to your grass folder (in Applications).
2. Select the GRASS program file. I did this for grass61cvs, but it should
work for grass60 also.
3. Hold down the control key and click with the mouse (or right click on a
3-button mouse).
4. Select "Show package contents"
5. Navigate to Contents/Resources/grass-6.1cvs/scripts (or
.../grass-6.0/scripts)
6. Put d.vect.thematic and v.univar.sh in the scripts folder
7. Voila, you can run them from the GRASS command line (I'll add them to the
GIS Manager menu soon).
Note that sometimes the execute permission gets turned off when these files
travel across the ether. You can not turn this on via the Mac "get info"
dialog for some weird reason. You can either use the chmod command from the
terminal to do this or download a nifty utility called BatChmod from
www.versiontracker.com that will allow you to set the execute permissions.
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Daniel Calvelo Aros <dcalvelo at minag.gob.pe>
> Reply-To: <daniel.calvelo at minag.gob.pe>
> Date: Fri, 20 May 2005 14:22:50 -0500
> To: Thomas Adams <Thomas.Adams at noaa.gov>, Michael Barton
> <michael.barton at asu.edu>
> Cc: <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] d.vect.thematic on Mac OS X
> I'm on MacOSX right now. Quick and dirty, since "." is in the PATH:
> 1. Unpack Michael's thematic.tgz;
> 2. start grass (I use 6);
> 3. within grass cd to the thematic/d.vect.thematic directory;
> 4. issue a 'cp ../v.univar.sh/v.univar.sh .'
> 5. presto.
> You won't see colors in the graphical legend, though (you need CVS for that).
> Daniel
> -- Daniel Calvelo Aros
> ---------- Original Message -----------
> From: "Thomas Adams" <Thomas.Adams at noaa.gov>
> To: Michael Barton <michael.barton at asu.edu>
> Cc: grass5 at grass.itc.it
> Sent: Fri, 20 May 2005 14:07:20 -0400
> Subject: [GRASS5] d.vect.thematic on Mac OS X
>> Michael,
>> I would like to play with d.vect.thematic. I have installed
>> LorenzoMoretti's GRASS distribution for Mac OS X for both 5.4 & 6.0
>> anduse both. What do I need to do to try it out? Thanks for your help.
>> Regards,
>> Tom
>> Michael Barton wrote:
>> If you want to change your local version, please go right ahead and
>> see how it looks.
>> Let's not change the cvs version until we have a consensus (if
>> possible). For work in my field (archaeology) and from what I know
>> of geography, the notation
>> ]min ; max]
>> would be meaningless--although it might be perfect for your field
>> Michael
>> USA
>> Date: Fri, 20 May 2005 12:22:08 -0500
>> To: Michael Barton <michael.barton at asu.edu>, Maciek Sieczka
>> <werchowyna at epf.pl>, Paolo Cavallini via RT <grass-
>> bugs at intevation.de> Cc: grass devel <grass5 at grass.itc.it> Subject:
>> Re: [GRASS5] Re: [bug #3246] (grass) d.vect.thematic fails when the
>> map is in another mapset
>> From: Michael Barton <michael.barton at asu.edu>
>> Sent: Fri, 20 May 2005 10:12:41 -0700
>> I tend to agree with you that
>> min - max
>> looks better than
>> min - max
>> although the second one is more accurate.
>> What does everyone else think?
>> I'd like the math standard :
>> [min ; cut1]
>> ]cut1 ; cut2]
>> ]cutn ; max]
>> Note the *included* min. I'll see if I can put that into your
>> current script, Michael.
>> Daniel.
>> grass5 mailing list
>> http://grass.itc.it/mailman/listinfo/grass5
>> Thomas E Adams
>> National Weather Service
>> Ohio River Forecast Center
>> 1901 South State Route 134
>> Wilmington, OH 45177
>> EMAIL: thomas.adams at noaa.gov
>> VOICE: 937-383-0528
>> FAX: 937-383-0033
> ------- End of Original Message -------
