[GRASS5] extend update command in GRASS SQL
Moritz Lennert
mlennert at club.worldonline.be
Wed May 25 04:21:37 EDT 2005
Hello,
How difficult would it be to extend the capacities of the UPDATE command in
the GRASS SQL ?
If I understand correctly, at the moment all one can do is to update a column
to a given fixed value. I haven't found a way to either update it with the
value of another column or (more importantly) with an expression such as set
col3=col1/col2. This would be quite useful.
Moritz
