[GRASS5] v.db.updatecol & v.db.addcol - draft version 2
Moritz Lennert mlennert at club.worldonline.be
Wed May 25 17:47:14 EDT 2005
Hello,
Here is the second draft version of my two little modules. I have implemented
the following changes:
- harmonized option names with general GRASS habits
- harmonized names of the two modules (*col for both instead of *column for one)
- now v.db.addcol accepts multiple columns
- added some little error checking
Any feedback welcome. If there are no serious problems, I will write the
description.html and check them into CVS pretty soon.
Moritz
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050525/653db539/v.db.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050525/653db539/v.db-0001.obj
