[GRASS5] v.db.updatecol & v.db.addcol - draft version 2
Lorenzo Moretti
lorenzo.moretti at bologna.enea.it
Thu May 26 05:26:10 EDT 2005
Hi Moritz
>Hello,
>Here is the second draft version of my two little modules. I have implemented
>the following changes:
>- harmonized option names with general GRASS habits
>- harmonized names of the two modules (*col for both instead of
>*column for one)
>- now v.db.addcol accepts multiple columns
>- added some little error checking
>Any feedback welcome. If there are no serious problems, I will write the
>description.html and check them into CVS pretty soon.
>Moritz
>Attachment converted: APPLI:v.db.addcol ( / ) (004A5BE5)
>Attachment converted: APPLI:v.db.updatecol 1 ( / ) (004A5BE6)
VERY GOOD !
I think that it's more easy for all user to add 1 only column any
time with a choice list of type, not a box.
It's not need for me to add many columns in one commands (or you can
repeat "name of new column" box and "type of the new column" list
more times - 2 or 3)
Bye
________________________________________________________________________
|| Lorenzo Moretti e-mail: lorenzo.moretti at bologna.enea.it
||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/
|| | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
