[GRASS5] Grass 6.0cvs 21/05/2005 on Solaris Sparc
Ade Fewings
ade at informatics.bangor.ac.uk
Sat May 28 13:19:33 EDT 2005
Thanks for your reply Glynn......see below my progress.....
>"6.0cvs"? The CVS head should be "6.1cvs".
6.0.1cvs, sorry about that typo.
>>A number of occurrences of not being able to find install-sh - typically
>>not enough or too many "../" - in builds in sub-directories of the grass
>>source. However, I can fix these myself for my purposes - should they
>>be fed back here for info?
>What is INSTALL set to in include/Make/Platform.make?
INSTALL = "../.././install-sh -c"
Quick change fixes that one.
Didn't realise I should be changing that, sorry.
>>Also had another problem linking with ncurses and undefined symbols
>>w32addch, getcurx, getcury and initscr32 in building lib/init,
>>display/d.colors, general/g.access, general/g.mapsets,
>>general/g.tempfile, imagery/i.class, imagery/i.cluster, etc. which I
>>had to fix by adding -lcurses to the LDFLAGS. Again, is this likely to
>>be Solaris limited or should it be fed back here?
>The relevant linking commands should use $(CURSES); if you can find
>specific examples where this switch isn't present, let us know.
I think it's an issue between Solaris supplied 'libcurses' and
non-Solaris supplied 'libncurses'. I don't think that $(CURSES) is
missing anywhere, I just think it hasn't been defined correctly for me.
Will just this out once i've discovered if my hack works or not.
>>Undefined first referenced
>> symbol in file
>>c::c(n6, (int0_t)) /opt/csw/lib/libGLU.so
>>__1cG__CrunKpure_error6F_v_ /opt/csw/lib/libGLU.so
>>sunOglCurPrimTablePtr
>>/export/data0/grass-6.0.cvs_src_snapshot_2005_05_21/dist.sparc-sun-solaris2.9/lib/libgrass_ogsf.so
>>sunOglCurrentContext
>>__1cG__CrunMex_rethrow_q6F_v_ /opt/csw/lib/libGLU.so
>>__1c2K6Fpv_v_ /opt/csw/lib/libGLU.so
>>__1c2k6Fpv_v_ /opt/csw/lib/libGLU.so
>>c::c(N6, (int0_t)) /opt/csw/lib/libGLU.so
>>ld: fatal: Symbol referencing errors. No output written to
>>/export/data0/grass-6.0.cvs_src_snapshot_2005_05_21/dist.sparc-sun-solaris2.9/bin/nviz
>>collect2: ld returned 1 exit status
>>gmake[1]: ***
>>[/export/data0/grass-6.0.cvs_src_snapshot_2005_05_21/dist.sparc-sun-solaris2.9/bin/nviz]
>>Error 1
>>gmake[1]: Leaving directory
>>`/export/data0/grass-6.0.cvs_src_snapshot_2005_05_21/visualization/nviz/src'
>>gmake: *** [nvwish] Error 2
>>Can anybody offer any guidance? libGLU and libGL are both in
>>/usr/openwin/lib which is included, so i'm not sure how to fix this.
>>Thanks in advance.
>It appears that /opt/csw/lib/libGLU.so is broken.
>I don't think that you can force the version in /usr/openwin/lib to be
>used instead simply by choosing configure switches.
>In that situation, the only solution which I can think of is to make a
>private libraries directory, populate it with symlinks to the
>necessary libraries in /opt/csw/lib (but not libGLU), then pass the
>private directory to configure instead of /opt/csw/lib.
Oh, of course. Must have been a long day, because I didn't spot the bit
where it said "/opt/csw/lib/libGLU.so" which was Blastwave's MesaGL
libraries instead of the Sun OpenGL libraries in /usr/openwin/lib. I
uninstalled the CSW mesa package and built again with success.
Once built, a couple of issues in trying to run......
1. The RPATH for the postgres libraries doesn't seem to have been
included into the built binaries. For me, simply a case of adding
"-R/opt/csw/postgresql/lib" to LDFLAGS and building again.
2. Trying to run Grass, it starts up OK and I select my data set OK and
then get the following error:
Welcome to GRASS 6.0.1cvs (2005)
GRASS homepage: http://grass.itc.it/
This version running thru: TC Shell (/bin/tcsh)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the graphical user interface with: d.m &
When ready to quit enter: exit
Mapset <afs091> in Location <machno>
GRASS 6.0.1cvs > Error in startup script: couldn't read file
"/usr/local/grass-6.0cvs21052005/grass-6.0.1cvs/etc/gtcltk/select.tcl":
no such file or directory while executing
"source $env(GISBASE)/etc/gtcltk/select.tcl"
(file
"/usr/local/grass-6.0cvs21052005/grass-6.0.1cvs/etc/dm/d.m.tcl" line 39)
GRASS 6.0.1cvs >
The file select.tcl is in the source tarball, so not sure why it has not
made its way during install.
Thanks once again,
Ade
___________________________________________________
Ade Fewings MEng
School of Informatics, University of Wales, Bangor,
Dean Street, Bangor, Gwynedd. LL57 1UT. UK.
ade at informatics.bangor.ac.uk www.informatics.bangor.ac.uk/~ade
Tel: +44 (0)1248 382736 Fax: +44 (0)1248 361429
