[GRASS5] Grass 6.0cvs 21/05/2005 on Solaris Sparc
Ade Fewings ade at informatics.bangor.ac.uk
Sat May 28 13:32:12 EDT 2005
> 2. Trying to run Grass, it starts up OK and I select my data set OK
> and then get the following error:
> Welcome to GRASS 6.0.1cvs (2005)
> GRASS homepage:                          http://grass.itc.it/
> This version running thru:               TC Shell (/bin/tcsh)
> Help is available with the command:      g.manual -i
> See the licence terms with:              g.version -c
> If required, restart the graphical user interface with: d.m &
> When ready to quit enter:                exit
> Mapset <afs091> in Location <machno>
> GRASS 6.0.1cvs > Error in startup script: couldn't read file
> "/usr/local/grass-6.0cvs21052005/grass-6.0.1cvs/etc/gtcltk/select.tcl":
> no such file or directory while executing
> "source $env(GISBASE)/etc/gtcltk/select.tcl"
>    (file
> "/usr/local/grass-6.0cvs21052005/grass-6.0.1cvs/etc/dm/d.m.tcl" line 39)
> GRASS 6.0.1cvs >
> The file select.tcl is in the source tarball, so not sure why it has
> not made its way during install.
Further to this, a load of .gif files from the source directory
display/d.m didn't get installed into
/usr/local/grass-6.0cvs21052005/grass-6.0.1cvs/etc/dm/.  I'm not sure if
that will have effected any other files where it is not so easy for
Grass to report that it can't find them.
Cheers
Ade
___________________________________________________
Ade Fewings MEng
School of Informatics, University of Wales, Bangor,
Dean Street, Bangor, Gwynedd. LL57 1UT. UK.
ade at informatics.bangor.ac.uk  www.informatics.bangor.ac.uk/~ade
Tel: +44 (0)1248 382736       Fax: +44 (0)1248 361429
