[GRASS5] Grass 6.0cvs 21/05/2005 on Solaris Sparc
Glynn Clements
glynn at gclements.plus.com
Sun May 29 08:00:41 EDT 2005
Ade Fewings wrote:
> >>A number of occurrences of not being able to find install-sh - typically
> >>not enough or too many "../" - in builds in sub-directories of the grass
> >>source. However, I can fix these myself for my purposes - should they
> >>be fed back here for info?
> >What is INSTALL set to in include/Make/Platform.make?
> INSTALL = "../.././install-sh -c"
> Quick change fixes that one.
> Didn't realise I should be changing that, sorry.
I would have expected configure to set it correctly itself.
Does it help if you specify the full path to configure, e.g.:
/usr/src/grass/configure ...
