[GRASS5] importing .e00 files
Kirk R. Wythers
kwythers at umn.edu
Wed Nov 2 12:54:54 EST 2005
Does anyone have any ideas as to what might be wrong with the
following command:
GRASS 6.1.cvs (arrowhead_utm):~ > v.in.e00 -v file=/Volumes/disk2/
data2/reich_lab/data/fia/glo10k.e00 type=area vect=glo10k
An error may appear next which will be ignored...
E00 Compressed ASCII found. Will uncompress first...
/usr/local/grass-6.1.cvs/scripts/v.in.e00: line 175: e00conv: command
not found
...converted to Arc Coverage in current directory
Importing areas...
ERROR: Cannot open data source: glo10k
An error occurred. Stop.
This files appears to open fine with ArcView, so I don't think the
file is bad. However, I am confused by the "can't open data source"
message.
Thanks,
Kirk
