[GRASS5] importing .e00 files
Kirk R. Wythers
kwythers at umn.edu
Thu Nov 3 10:24:53 EST 2005
Hey Shaun,
I'm still having some trouble with those .e00 files. I built avce00
and e00compr, and installed:
e00conv
avcdelete
avcexport
avcimport
avctest
in /usr/local/bin
I am no longer getting the error e00conv not found, but I still get
the error "can't open data source:"
GRASS 6.1.cvs (arrowhead_utm):~ > v.in.e00 -v file=~/Desktop/
glo10k.e00 type=area vect=glo10k
An error may appear next which will be ignored...
E00 Compressed ASCII found. Will uncompress first...
...converted to Arc Coverage in current directory
Importing areas...
ERROR: Cannot open data source: glo10k
An error occurred. Stop.
Am I still missing something?
On Nov 2, 2005, at 12:29 PM, Shaun Walbridge wrote:
> Hi Kirk,
> You can just build avce00. It should be pretty straightforward to
> set up. Then either install the binaries to somewhere on your
> $PATH, or edit v.in.e00 to point to the locations. The GRASS dev
> folks should probably include it as a configure option, but I guess
> they see it as being external to the core GRASS stuff.
> - Shaun
> Kirk R. Wythers wrote:
>> Thanks Shaun. Does grass need to be re-compiled, or can I just
>> build avce00?
>> On Nov 2, 2005, at 12:05 PM, Shaun Walbridge wrote:
>>> Kirk,
>>> The v.in.e00 script is dependent on your system having avce00
>>> already installed. You can download this library at: http://
>>> avce00.maptools.org/.
>>> -Shaun
>>>> Does anyone have any ideas as to what might be wrong with the
>>>> following command:
>>>> GRASS 6.1.cvs (arrowhead_utm):~ > v.in.e00 -v file=/Volumes/
>>>> disk2/ data2/reich_lab/data/fia/glo10k.e00 type=area vect=glo10k
>>>> /usr/local/grass-6.1.cvs/scripts/v.in.e00: line 175: e00conv:
>>>> command not found
>>>> Importing areas...
>>>> This files appears to open fine with ArcView, so I don't think
>>>> the file is bad. However, I am confused by the "can't open
>>>> data source" message.
>>>> Thanks,
>>>> Kirk
>>>> _______________________________________________
>>>> grass5 mailing list
>>>> grass5 at grass.itc.it
>>>> http://grass.itc.it/mailman/listinfo/grass5
