[GRASS5] importing .e00 files
Markus Neteler
neteler at itc.it
Thu Nov 3 17:27:28 EST 2005
Hi Kirk,
please edit the first line of the v.in.e00 script
(run 'which v.in.e00' to find it, if that works on Mac)
and add
-x
to the first line. Then run again and it will print every step.
Please post the relevant part of the output.
Markus
On Thu, Nov 03, 2005 at 09:24:53AM -0600, Kirk R. Wythers wrote:
> Hey Shaun,
> I'm still having some trouble with those .e00 files. I built avce00
> and e00compr, and installed:
> e00conv
> avcdelete
> avcexport
> avcimport
> avctest
> in /usr/local/bin
> I am no longer getting the error e00conv not found, but I still get
> the error "can't open data source:"
> GRASS 6.1.cvs (arrowhead_utm):~ > v.in.e00 -v file=~/Desktop/
> glo10k.e00 type=area vect=glo10k
> An error may appear next which will be ignored...
> E00 Compressed ASCII found. Will uncompress first...
> ...converted to Arc Coverage in current directory
> Importing areas...
> ERROR: Cannot open data source: glo10k
> An error occurred. Stop.
> Am I still missing something?
> On Nov 2, 2005, at 12:29 PM, Shaun Walbridge wrote:
> >Hi Kirk,
> >You can just build avce00. It should be pretty straightforward to
> >set up. Then either install the binaries to somewhere on your
> >$PATH, or edit v.in.e00 to point to the locations. The GRASS dev
> >folks should probably include it as a configure option, but I guess
> >they see it as being external to the core GRASS stuff.
> >- Shaun
> >>Thanks Shaun. Does grass need to be re-compiled, or can I just
> >>build avce00?
> >>On Nov 2, 2005, at 12:05 PM, Shaun Walbridge wrote:
> >>>Kirk,
> >>>The v.in.e00 script is dependent on your system having avce00
> >>>already installed. You can download this library at: http://
> >>>avce00.maptools.org/.
> >>>-Shaun
> >>>>Does anyone have any ideas as to what might be wrong with the
> >>>>following command:
> >>>>GRASS 6.1.cvs (arrowhead_utm):~ > v.in.e00 -v file=/Volumes/
> >>>>disk2/ data2/reich_lab/data/fia/glo10k.e00 type=area vect=glo10k
> >>>>/usr/local/grass-6.1.cvs/scripts/v.in.e00: line 175: e00conv:
> >>>>command not found
> >>>>Importing areas...
> >>>>This files appears to open fine with ArcView, so I don't think
> >>>>the file is bad. However, I am confused by the "can't open
> >>>>data source" message.
> >>>>Thanks,
> >>>>Kirk
> >>>>_______________________________________________
> >>>>grass5 mailing list
> >>>>grass5 at grass.itc.it
> >>>>http://grass.itc.it/mailman/listinfo/grass5
> grass5 mailing list
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
