[GRASS5] importing .e00 files
Kirk R. Wythers kwythers at umn.edu
Thu Nov 3 18:14:36 EST 2005
On Nov 3, 2005, at 4:27 PM, Markus Neteler wrote:
> Hi Kirk,
> please edit the first line of the v.in.e00 script
> (run 'which v.in.e00' to find it, if that works on Mac)
> and add
>  -x
> to the first line. Then run again and it will print every step.
> Please post the relevant part of the output.
Markus,
I think this is the relevant output...
+ echo 'E00 Compressed ASCII found. Will uncompress first...'
+ rm -rf glo10k info
+ e00conv /Network/Servers/truffula.fr.umn.edu/Volumes/disk1/home1/
kwythers/Desktop/glo10k.e00 13707.e00
+ echo '...converted to Arc Coverage in current directory'
+ avcimport 13707.e00 glo10k
++ echo glo10k
++ sed s+-+_+g
+ NAME=glo10k
+ '[' area = point ']'
+ '[' area = line ']'
+ '[' area = area ']'
+ echo 'Importing areas...'
Importing areas...
+ v.in.ogr -c -o dsn=glo10k layer=LAB,ARC type=centroid,boundary
output=glo10k
ERROR: Cannot open data source: glo10k
+ '[' 1 -eq 1 ']'
+ echo 'An error occurred. Stop.'
+ rm -rf 13707.e00 glo10k info
+ exit 1
GRASS 6.1.cvs (arrowhead_utm):~ >
It's still that same "Cannot open data source: glo10k
> Markus
> On Thu, Nov 03, 2005 at 09:24:53AM -0600, Kirk R. Wythers wrote:
>> Hey Shaun,
>> I'm still having some trouble with those .e00 files. I built avce00
>> and e00compr, and installed:
>> e00conv
>> avcdelete
>> avcexport
>> avcimport
>> avctest
>> in /usr/local/bin
>> I am no longer getting the error e00conv not found, but I still get
>> the error "can't open data source:"
>> GRASS 6.1.cvs (arrowhead_utm):~ > v.in.e00 -v file=~/Desktop/
>> glo10k.e00 type=area vect=glo10k
>> An error may appear next which will be ignored...
>> Importing areas...
>> Am I still missing something?
>> On Nov 2, 2005, at 12:29 PM, Shaun Walbridge wrote:
>>> Hi Kirk,
>>> You can just build avce00. It should be pretty straightforward to
>>> set up. Then either install the binaries to somewhere on your
>>> $PATH, or edit v.in.e00 to point to the locations. The GRASS dev
>>> folks should probably include it as a configure option, but I guess
>>> they see it as being external to the core GRASS stuff.
>>> - Shaun
>>>> Thanks Shaun. Does grass need to be re-compiled, or can I just
>>>> build  avce00?
>>>> On Nov 2, 2005, at 12:05 PM, Shaun Walbridge wrote:
>>>>> Kirk,
>>>>> The v.in.e00 script is dependent on your system having avce00
>>>>> already installed.  You can download this library at: http://
>>>>> avce00.maptools.org/.
>>>>> -Shaun
>>>>>> Does anyone have any ideas as to what might be wrong with the
>>>>>> following command:
>>>>>> GRASS 6.1.cvs (arrowhead_utm):~ > v.in.e00 -v file=/Volumes/
>>>>>> disk2/  data2/reich_lab/data/fia/glo10k.e00 type=area vect=glo10k
>>>>>> /usr/local/grass-6.1.cvs/scripts/v.in.e00: line 175: e00conv:
>>>>>> command  not found
>>>>>> Importing areas...
>>>>>> This files appears to open fine with ArcView, so I don't think
>>>>>> the  file is bad. However, I am confused by the "can't open
>>>>>> data  source"  message.
>>>>>> Thanks,
>>>>>> Kirk
>>>>>> _______________________________________________
>>>>>> grass5 mailing list
>>>>>> grass5 at grass.itc.it
>>>>>> http://grass.itc.it/mailman/listinfo/grass5
>> grass5 mailing list
> Markus Neteler     <neteler itc it>       http://mpa.itc.it
> ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18        -       38050 Povo (Trento), Italy
