[GRASS5] [bug #3170] (grass) v.label help mentions p.map, which is gone
Maciek Sieczka via RT
grass-bugs at intevation.de
Fri Nov 4 04:00:08 EST 2005
Dan Jacobson <jidanni at jidanni.org> wrote:
>v.label help mentions p.map, which is gone.
>d.paint.labels help also mentions some p things.
>g.manual v.label doesn't say what d program one uses to display the labels.
These are fixed as I can see.
>And this probably is busted these days:
>v.label -a map=contourtest5 column=level labels=contourtest8
>Labeled 57 lines.
>d.paint.labels labels=contourtest8Dan
>Error: rotate: 15.924559...
>Without the -a the error messages are gone, but it just draws circles on
>the monitor, just the same.
What about this one? Anybody?
>P.S.
>v.out.ascii contourtest5 out=contourtest99
>find ~jidanni/tmp/grassdata -cmin -1
>doesn't find anything, nor does -mmin, i.e., v.out.ascii doesn't do anything
>anymore.
And this, does anybody know?
Maciek
P.S.
Dan, could you retest and post an update or tell me to close the bug?
-------------------------------------------- Managed by Request Tracker
