[GRASS5] [bug #3170] (grass) v.label help mentions p.map, which
is gone
Hamish
hamish_nospam at yahoo.com
Fri Nov 4 08:41:17 EST 2005
> >And this probably is busted these days:
> >v.label -a map=contourtest5 column=level labels=contourtest8
> >Labeled 57 lines.
> >d.paint.labels labels=contourtest8Dan
> >Error: rotate: 15.924559...
> >Without the -a the error messages are gone, but it just draws circles
> >on the monitor, just the same.
> What about this one? Anybody?
I did a bit of a fix up on d.paint.labels in June to support rotated
text. Everything should be a-ok now.
> >v.out.ascii contourtest5 out=contourtest99
> >find ~jidanni/tmp/grassdata -cmin -1
> >doesn't find anything, nor does -mmin, i.e., v.out.ascii doesn't do
> >anything anymore.
> And this, does anybody know?
Only features with a category number will be exported. In points mode
only points will be exported. I've added a note to the help page.
Closing the bug.
Hamish
