[GRASS5] [bug #3800] (grass) script tests fail on some platforms
Glynn Clements
glynn at gclements.plus.com
Sat Nov 5 12:38:57 EST 2005
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3800
> Subject: script tests fail on some platforms
> see http://grass.itc.it/pipermail/grass5/2005-November/020021.html
> this seems to fail on some platforms:
> E00CONV="`which e00conv`"
> if [ "$EOOCONV" == "" ] ; then
"==" isn't valid expression syntax; it's just "=".
