[GRASS5] [bug #3800] (grass) script tests fail on some platforms
Request Tracker grass-bugs at intevation.de
Thu Nov 3 19:37:16 EST 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3800
Subject: script tests fail on some platforms
see http://grass.itc.it/pipermail/grass5/2005-November/020021.html
this seems to fail on some platforms:
E00CONV="`which e00conv`"
if [ "$EOOCONV" == "" ] ; then
  echo error
  exit
fi
works:
  if [ -z "$E00CONV" ] ; then
probably also
  if [ "$VAR" != "" ] ; then
should be
  if [ -n "$VAR" ] ; then
affected modules:
> $ grep -rI '""' scripts/* | cut -f1 -d/ | sort | uniq
> d.correlate
> d.monsize
> d.out.file
> d.rast.leg
> d.resize
> d.slide.show
> d.split
> d.vect.thematic
> db.test
> g.mlist
> g.mremove
> i.fusion.brovey
> i.image.mosaic
> i.in.spotvgt
> i.oif
> i.spectral
> i.tasscap
> r.fillnulls
> r.in.aster
> r.in.srtm
> r.mapcalculator
> r.plane
> r.reclass.area
> r.regression.line
> r.shaded.relief
> r.univar.sh
> r3.mapcalculator
> v.build.all
> v.convert.all
> v.db.addcol
> v.db.addtable
> v.db.droptable
> v.db.reconnect.all
> v.db.update
> v.in.gns
> v.in.mapgen
> v.in.sites.all
> v.rast.stats
> v.univar.sh
Hamish
-------------------------------------------- Managed by Request Tracker
