[GRASS5] Re: [GRASSLIST:8980] pj_do_proj
Paul Kelly paul-grass at stjohnspoint.co.uk
Thu Nov 10 11:16:54 EST 2005
Hello Ed
On Thu, 10 Nov 2005, Ed Davison wrote:
> I am update a GRASS 5.x module that has calls to pj_do_proj in the
> source code to change lat/lon coords to UTM.  I cannot find any sort of
> "do projection" call in the GRASS programmer manuals (I have checked the
> vector, gis, 3d and dbmi manuals so far).
> Can someone point me in the right direction as to what the new calls
> would be?
pj_do_proj() should still work fine in the latest versions of GRASS. Did
something not work or is a reason why you think it shouldn't work?
Paul
