[GRASS5] Re: [GRASSLIST:8980] pj_do_proj
Markus Neteler neteler at itc.it
Thu Nov 10 11:10:13 EST 2005
(switched to dev ML)
On Thu, Nov 10, 2005 at 09:44:59AM -0600, Ed Davison wrote:
> I am update a GRASS 5.x module that has calls to pj_do_proj in the
> source code to change lat/lon coords to UTM.  I cannot find any sort of
> "do projection" call in the GRASS programmer manuals (I have checked the
> vector, gis, 3d and dbmi manuals so far).
> Can someone point me in the right direction as to what the new calls
> would be?
I have added a draft doxygen file at
 lib/proj/projlib.dox
which needs to be extended. The available functions are also
found there.
 Markus
